MC battery door
sleepyhollow
MC battery door
Hi, does anyone make the correct battery door for a MC or have a photo of an original so I can modify one? Thanks.
The exact original is not made by anyone. I may have an NOS one left, or can get a new reproduction that I can explain to you how to make it work, and will not be any different from the outside vs original.
Howard Yoder
Pins that go in holes is what the 40 and 420 use. MC is supposed to be a two piece hinge setup that you can remove the door. Only thing available any more is a non-removable hinge door. You weld the hinge at 90 degrees, and put pins in place of the hinge bolts and mount it like the 40/420.
The NOS one I have is original MC.
