Safe to Tow?
kratester
Safe to Tow?
Post by kratester » Mon Nov 06, 2006 9:05 am
All right, now that it seems that I've got a problem with the isolator, should I have any concerns about towing this machine down off the hill to the garage. Mainly worried about the broken spring(s) jamming and causing damage. Tranny is in nuetral and reverser is positioned there too.
1966 JD 350 crawler loader
CatD8RII
Post by CatD8RII » Thu Nov 09, 2006 9:14 am
It should be OK. Be nice to know if the brakes work before you start down the hill. If I remeber right they should roll freely just with the trans in N
Post by Lavoy » Thu Nov 09, 2006 10:21 am
With the trans in neutral, there is no link to the input shaft to the trans, so no power will be fed into the reverer. Plus, if the engine is off, there is no pressure to engage the clutch packs in the reverser, so no problem.
kratester
Post by kratester » Thu Nov 09, 2006 2:06 pm
OK many thanks for the replies; we'll give it a go.
Users browsing this forum: No registered users and 440 guests
