update... 420 run problem
theshanmand1!
Post by theshanmand1! » Mon Mar 31, 2014 8:14 pm
hello all,
just wanted to update you all and thank you for your help finding the problem-s :D
installed the new intake/exhaust manifold sunday. it runs great!
thanks again.
does anyone have any suggestions for new blade lift cylinders, I see that northern tool has some but don't know what pressure the 420 hyd. manifold builds.
yard dog
1958 4 Roller 4 speed Holt Blade Holt Winch
420 C
Industrial Yellow
dkokai76
Post by dkokai76 » Mon Mar 31, 2014 9:58 pm
What condition are the old ones? I would try and find someone to rebuild the old ones if possible. New cylinder can get pricey.
1958?? 420 C 5 Roller
1980 350 C
Post by Lavoy » Tue Apr 01, 2014 8:01 am
420C runs at about 1000PSI, nothing Northern tool has will be rated anywhere near that low, you will be fine.
theshanmand1!
Post by theshanmand1! » Tue Apr 01, 2014 9:17 am
Thanks lavoy
yard dog
420 C
Industrial Yellow
theshanmand1!
Post by theshanmand1! » Tue Apr 01, 2014 9:22 am
How about blade arm bushings, the holes in the blade arms are wallered out & the bosses are egg shape. I was thinking of just getting a set of bushings and welding them on and building up weld on the inside, any suggestions?
yard dog
420 C
Industrial Yellow
Post by Lavoy » Tue Apr 01, 2014 3:27 pm
Other option is to bore oversize and bush back down to correct size.
theshanmand1!
Post by theshanmand1! » Fri Apr 04, 2014 9:24 pm
sounds good,
it took a lot of the red wrench, :o but I got the two bolts out that hold the holt blade arm to the crossbar. the blade is off and the blade arm boss holes are 2". bushing research time. :)
would someone tell me if the roller frame cross member bosses that the caps screw down on, to hold the roller frame to the cross member are forged steel or cast?
the reason I am asking is some of the bolts that hold the caps on are looking pretty rotten and I know I will have to bring the heat :lol: to get them off, and I don't want to temper the bosses if they are cast.
thank you for all of your help :D
yard dog
420 C
Industrial Yellow
Post by Lavoy » Sat Apr 05, 2014 9:37 am
They are cast, but cast steel, heated tons of them over the years, usually only way to get the bolts out.
theshanmand1!
Post by theshanmand1! » Sat Apr 05, 2014 9:40 am
Thank you Lavoy, you are the man!
Full speed ahead!
yard dog
420 C
Industrial Yellow
Users browsing this forum: jimmydiesel and 9 guests
