You Opinion on if 420 has enough power for this.
dr1zsk1
Post by dr1zsk1 » Tue May 06, 2014 4:52 pm
I have a chance to buy this.
Will a 420 have enough power for this? It weights quite a bit.
I can also cut the front two teeth off and just use the back three.
I have been using it and it seems to push the 420 pretty hard -- I have to pull in 1st gear -- it cuts and works but when I'm backing and turning with it on it tries to pull the tracks.
If man can break it man can fix it .. it just takes time and money.
gregjo1948
Post by gregjo1948 » Tue May 06, 2014 6:25 pm
I don't think your 420 is enough machine to fully engage this machine and pull it. Maybe if you gauge the depth it sinks, it would pull it thru easy soil. It looks like something that should be attached to a 450. I think it's going to harm you're 420. gregjo1948
Post by Lavoy » Tue May 06, 2014 7:30 pm
Given the cost and/or scarcity of the parts you will in all likelihood be breaking eventually, I would probably not do it.
Post by jtrichard » Tue May 06, 2014 10:30 pm
i would think about cutting the three off and leave the two that's about all you should try to pull with a small machine like you have
whiteclipse16
Post by whiteclipse16 » Wed May 07, 2014 6:01 am
I'm with these guys however it sounds like your issue is the weight when it's not in the ground as opposed to the machine having enough power to pull it.
On a different note, that is one heck of a piece of equipment. Should really tear the ground up.
Ben
Pat
Post by Pat » Wed May 07, 2014 6:44 am
I wouldn't take the chance of busting that nice 3 point. I'd look for a smaller scarifier, or even a box blade with shanks.
Post by Stan Disbrow » Wed May 07, 2014 6:59 am
I agree. That looks like about twice as much weight and load as a poor old 420 wants to see.....
dr1zsk1
If I cut off the two outside rear teeth.
Post by dr1zsk1 » Wed May 07, 2014 10:23 am
ImageERE IT IS.
Post by Lavoy » Wed May 07, 2014 3:41 pm
That would be a lot better setup.
gus
Post by gus » Wed May 07, 2014 3:50 pm
Looks like way to much wt hanging way out back. Maybe remove the back 3 to put the pull closer to the crawler?
Is that a 4 roller?? Even less balance.
Post by Stan Disbrow » Wed May 07, 2014 6:52 pm
Yes, three of the teeth it ought to pull OK, and the diet you are planning ought to make it within the lifting range.
dr1zsk1
A big thanks --
Post by dr1zsk1 » Wed May 07, 2014 7:58 pm
I'll post pictures after I get it done. I am going to try to make some gauge wheels for it as well. I have a pair of wheels on an old spring plow that may work. That way I can just run it in float.
gregjo1948
Post by gregjo1948 » Thu May 08, 2014 5:18 am
Seems a shame to cut up this huskie ripper. I think you should sell it and get a more sensible size box blade with rippers. gregjo1948
dr1zsk1
make an offer before 8 tonight lol
Post by dr1zsk1 » Thu May 08, 2014 8:58 am
All bids welcome
gregjo1948
Post by gregjo1948 » Fri May 09, 2014 2:59 am
I'd like it but, I'm upstate NY. Shipping alone would kill me. gregjo1948
