jd2010 sn32487
dtoots1
jd2010 sn32487
Post by dtoots1 » Tue Jun 03, 2014 8:11 am
well guys Lavoy got the vavles to me yesterday and i took head to mach shop to get er done....also took my exhaust manifold in had him look at it...ports 2 and 3 are weak and on the thin side.......so am in need of exhaust manifold!!!!
anyone got one available? send me a pm with info
also...any chance of building a set of headers like they do for automobiles????...kinda doubt it as intake is part of set up..
what about brazing with a header plate for both intake and exhaust and fill in the weak area with brazing??? i sure dont know
by the way...i went to harbor frt the other day and bought a 6inch extended digital caliper... which measures outside dims only.....however is enough taper and room to add points to the outside and add that distance to the inside dims and will then do both jobs...will do job that i need done and dont have to invest in set of micrometers
thanks
dtoots1
Post by Lavoy » Tue Jun 03, 2014 1:32 pm
Can you surface the manifold and get by?
dtoots1
jd2010 sn32487
Post by dtoots1 » Tue Jun 03, 2014 1:49 pm
dont think so....did not measure thickness of wall...but it appears about 1/8 inch wall thickness...will measure when get back
dtoots1
Re: pre 42000 jd2010 gas
Post by dtoots1 » Mon Jun 09, 2014 8:28 am
well folks.....forgot to mention that this is a gas job.....
guess most of u folks have the diesel and no one seems to have a manifold available....willl the wheeled manifolds fit this dozer??? i did see a thread where someone mentioned they had to modify one from a wheeled unit tho they did not specify how they had to modifyit.....
Lavoy any word yet on the head set gaskets???
thks
dtoots1
dtoots1
thks
dtoots1
Post by Lavoy » Mon Jun 09, 2014 9:01 am
I think wheel tractor is different, but could be wrong. Head set is leaving today, FINALLY!
Thanks,
dtoots1
p
Post by dtoots1 » Mon Jun 09, 2014 9:07 am
thks for that info....
gonna try a tractor boneyard to see what they may have.
found a outfit with manifold surfacer....costs $50 to surface...but even he said it mite not do what we need......
so will keep looking a bit..
thks
dtoots1
dtoots1
Re: pre 42000 jd2010 gas exhaust manifold
Post by dtoots1 » Fri Jun 13, 2014 11:42 am
got it from boneyard....wheeled tractor and crawlers use same one fact is part number is same....only difference i see is whld outer face is flat crawlers is more streamlined...back on and together just waiting for alternator and fan belt from owner getting alt checked out....
meanwhile while cruising boneyards i found a rental outfit has a jd350 i couldnt find it in the weeds /trees so will need to look again..claims is a working machine but if trees/weeds hiding mite be a has been..
will see soon
tks for all help
dtoots1
