1010CA Rebuild Project
Post by wwattson » Sun Nov 19, 2006 4:50 pm
Thought I'd throw a few of the photos of the rebuild project up on the Show and Tell forum for anyone interested. Pulled the engine out this weekend and mounted it to the engine stand to start the teardown.
Here's the crawler with the front sheet metal removed.
A picture of the blade removed. Lavoy told me that this is a 63 blade on the 440 but if anyone knows if it is the same number on a 1010, I'd appreciate a reply back.
Got it off the crawler.
Crawler light one engine.
Here's the lifting setup I used. The bar on the top is just a 3/8" x 2" cold rolled mild steel bar out of my welding stock. The holes are 7/16" and drill at center and 7" either side of center. The holes are centered 3/4" from the edges with the center hole toward the top edge and the other two toward the bottom edge. This gives enough clearance for the links to hook through the holes and hang straight.
The eye nuts are McMaster Carr 3/8" - 16 forged steel oval (Part #3019T16). The 1010 uses 7/16" - 20 studs and as best I can tell you'll never find NF eye nuts so these are drilled out and tapped to the correct thread. The Deere part number is a JD218 but they are $60 a piece through my dealer. These are $6 a piece and 10 minutes work.
Don't know if anyone is interested to see this as it progresses. Let me know either way and I'll either post pictures from time to time or keep it to myself.
steamfitter99
1010 rebuild
Post by steamfitter99 » Sun Nov 19, 2006 6:16 pm
Bill,
Thanks for the photos! I would appreciate seeing your progress. I have this week off and one of my main projects is to get my 440 in the shop for some tlc. Thanks, Tom.
bighamlin
Post by bighamlin » Sun Nov 19, 2006 8:31 pm
Please - Keep posting, so I know what I will be going through this winter.
Post by JD440ICD2006 » Sun Nov 19, 2006 9:20 pm
Bill,
I think there is plenty of interest on here to see the "play by play" of that restoration.
I look forward to seeing the next batch of pictures and reading the notes.
JD430C
Post by JD430C » Sun Nov 19, 2006 9:50 pm
thanks for the pics bill, keep them coming. i am going to do the same to my 450c pretty soon. i have a 610 blade off a 1010 and it looks identical to the one on yours.
andrew
spooler
Post by spooler » Mon Nov 20, 2006 3:41 pm
Oh Yea, please keep the pics coming...
chuck
whybill
Post by whybill » Mon Nov 20, 2006 9:28 pm
This is great Bill I sure like to see what is going on...... I am going to have to rebush all of my blade joints soon and is is good to see the blade off one of these crawlers. the one on my 420 is considerably lighter than yours but I think that the 420 is a lighter tractor also. Keep the pics coming for sure.
Bill
Bill 420c dozer 5 roller
N. E. Alabama
older is better just keep it greased
Post by Stan Disbrow » Tue Nov 21, 2006 11:00 am
Yes, I think the blade model numbers from the 440 carried over to the 1010, so this would be a model 63 in both cases.
The 63 blade and frame is pretty much the same as the 62 blade used on the 420, as far as I could ever tell. The only obvious difference is that the mounting frame for the lift cylinders was made from bar stock on the 62 (open thru the center) and is made from heavy gauge sheet stock on the 63. The rest appears to be identical.
Bret4207
Post by Bret4207 » Sat Jan 06, 2007 6:50 pm
Nice shots. I hate people like you that have a real garage!!! Is that a South Bend Lathe in the background? Got a little 6" Atlas and 7" Atlas Shaper. Real handy to have.
Post by wwattson » Sat Jan 06, 2007 7:05 pm
Yup, it's a South Bend 13" that I'm in the process of restoring and using. It's getting repainted one or two pieces at a time. There is also a Bridgeport Series I mill in some of the shots as well. Both have come in pretty handy for making simple parts or repairing parts that have been broken. I just finished the shop late summer. It's about 60% of a 36' x 60' pole building with both wood and gas furnaces. It's the nicest set-up I've ever had.
After I get done with all the tractors I'm thinking about building an airplane. I've been flying for over 20 years and it would be nice to fly something I've actually built.
I'm on the South Bend Lathe and Bridgeport Mill groups on Yahoo as well as the casting hobby group. I'd recommend all of these groups to anyone that has the interest.
Sorry for the off topic post in the Show and Tell section but I wanted to answer the question and I've gotten to really like the fact I can make stuff I can't buy or find. Appreciate you noticing the machinery.
Users browsing this forum: No registered users and 154 guests
