Model 420 hydraulic blade question.
Is there an adjustment on the control valves so you may stop blade at any height?
Not sure I understand the question? When you let go of the hyd lever, the blade should stop moving no matter where it is at.
Usually that is bad cylinder seals, either way, not a setting on the valve.
Yes, since each cylinder only has about the capacity to lift half of the blade weight on a 62 (the model number of the bulldozer attachment).
Check with a local hyd shop, if not, give me a call.
Users browsing this forum: No registered users and 97 guests
