2010 alternator addition
vailvalley59
Post by vailvalley59 » Sat Dec 06, 2014 9:49 am
I finally hooked up a Delco 10si unit to the dozer. It is charging but at a rate of 16 volts--seems too high to me. Some one had put a voltmeter on the unit so it was there--had too change leads to negative ground. I took the alternator to Advance store and had it tested last night and they said it was fine--what do I do now? thanks
2010 diesel loader, IH 886, Cat 1947 D4 dozer, IH 966, Ford 7000, IH 2500, IH 706 and other toys
gregjo1948
Post by gregjo1948 » Sat Dec 06, 2014 10:10 am
16 volts is definetly too high. What did Advance say it was charging? You can probably install a new internal regulator. gregjo1948
Post by jtrichard » Sat Dec 06, 2014 10:58 am
Get a hand held meter and check the voltage if your dash meter is a cheepie it could be off
vailvalley59
Post by vailvalley59 » Sat Dec 06, 2014 7:22 pm
The voltmeter works quite well when compared to a hand-held meter. Could the wiring hookup be a problem? I will tell how I have the system wired up:
The Batt terminal is connected to the battery cable (plus) at the starter.
the #2 terminal is connected to the Batt terminal on the alternator
the #1 terminal is connected to the ignition switch at a switched 12v terminal. Anyone have any thoughts as to this being correct? I got this setup from the internet on an old tractor site--don't remember which one. No light bulb is involved in the circuit. By the way, Advance testing could not tell me what voltage was being put out--the machine just ended up saying the "unit is OK" Thanks
Post by jtrichard » Sun Dec 07, 2014 12:47 am
vailvalley59
Post by vailvalley59 » Fri Dec 19, 2014 1:02 pm
Removed alternator and changed voltage regulator to a used one I had on hand--unit is now charging at 14.9 volts--seems to be OK--used the same wiring as the last time.
Users browsing this forum: No registered users and 20 guests
