FUEL INJECTION PUMP QUESTION FOR J. DEMARIS OR ANYBODY ELSE
FL450B
Post by FL450B » Thu Apr 23, 2015 4:36 pm
I HAVE A FORD A62 WHEEL LOADER WITH A 256TD MOTOR WITH A MINIMEC
FUEL INJECTION PUMP....IF I LET THE MACHINE SIT FOR A DAY OR SO, I HAVE TO RE-BLEED THE INJECTORS....CHECKED ALL INCOMING HOSES AND LINES.....THOUGHT CHECK-VALVE MAY BE THE ISSUE...REPLACED THE CHECK-VALVE.....STILL THE SAME ISSUE.......NO EXCESS FUEL IN PUMP OR CRANKCASE..............RACK MOVES FINE AND EXCESS FUEL BUTTON MOVES RACK OVER LIKE IT SHOULD........ANY INPUT WOULD BE GREAT.
vailvalley59
Post by vailvalley59 » Sat Apr 25, 2015 8:02 am
I had a similar problem with a diesel car that I owned--got hold of a spray can of a white chalk and coated the fittings that went to the injectors--found a small leak that was not visible--tightened up connection and the problem was solved.. It acted as you said--would start fine if you ran it everyday--but would not start if it sat for several days. This was a Roosamaster type pump--your might not be the same type.
2010 diesel loader, IH 886, Cat 1947 D4 dozer, IH 966, Ford 7000, IH 2500, IH 706 and other toys
MarkW
Post by MarkW » Sun May 17, 2015 12:38 pm
For these leaks, as mentioned a spray can of talc works great. I use athletes foot spray with the powder added, you can get it in most any store and if you have teenagers it always seems to get used instead of sitting around for years like other service chemicals.
FL450B
UPDATE ON INJECTION PUMP
Post by FL450B » Mon May 18, 2015 2:42 pm
FOUND THAT THE PISTIONS IN EACH OF THE 4 SMALL PUMPS INSIDE PUMP WERE WORE AND NEEDED A REBUILD
