jd 420c big problem
jd 420c big problem
notice my crawler starting to have blue smoke coming from muffler, then when and check my radiator, was all black(engine oil was in there). anybody know what going on. i'm thinking head gasket, not sure. thanks
- mapaduke@yahoo.com
Admittedly I don't know much about this particular engine, but you may have water in the engine oil and not know it because it settles to the bottom of the oil pan and the oil floats above it. Usually you would see the mixing on a dipstick when running but may not always be obvious. Have you opened the oil pan drain plug to see if water comes out of it?
Users browsing this forum: Google [Bot] and 48 guests
