Steering brake making unusual noise
Post by Paul Buhler » Fri Sep 18, 2015 7:34 am
Found this on a Corvette site:
Let me expand on the previous post. Water DOES cool better, but only to 212 F (boiling point). Your C5 must actually cool past 236 F, so you HAVE to use coolant.
Coolant also protects metals and lubricates the water pump.
Makes sense to me. I run an antifreeze mix, and my old pump and radiator was/is nice and clean inside. The pump I rebuilt had run with water only - rusty with corrosion buildups around the impeller. Because of where I live, antifreeze is a must.
Post by Tigerhaze » Fri Sep 18, 2015 12:26 pm
The coolant changes both the freezing and boiling points of the mixture. However even that mixture can boil in an engine without help-the reason radiator systems are pressurized is to further raise that boiling point (conversely lower pressure is also why you can boil water on a mountaintop and it is cool enough to stick your hand in it). 212 F/ 32F are at standard pressure (approximately sea level).
I found this read at one point and has a few more specifics:
http://auto.howstuffworks.com/cooling-system3.htm
Post by Paul Buhler » Mon Oct 12, 2015 5:18 pm
Lawn ornaments finally back where they belong. I replaced the bent angle iron on my canopy, and straightened the whole unit so that it looks good in my eyes.
Machine is running and working well. Some paint and a few tweaks are still needed, but now I can get on with my Fall chores.
Thanks to everyone who shared their thoughts as I worked through this project. Paul
michaelkittrell
Post by michaelkittrell » Mon Oct 12, 2015 5:28 pm
Nicely done.
Re: Steering brake making unusual noise
Post by Paul Buhler » Mon Jun 25, 2018 8:01 pm
Hi: Just ran across this posting which seems to have regained the photo links from Photobucket. Has this occurred site wide? I sure hope so, a lot of people put a lot of energy into sharing their work and pictures which I have found to be invaluable as I work through my machine's upgrades. Paul
Post by Stan Disbrow » Tue Jun 26, 2018 4:28 am
I don't know as I went and loaded my pics onto the new photo host site and then deleted everything off PhotoBucket rather than pay them anything. It might be that was a trend PB-wide and they gave up trying to get folks to pay?
Post by Lavoy » Tue Jun 26, 2018 8:53 am
Wonder if they had so much backlash that they reinstated it? Need to find some other pic posts and see if they work.
Post by Lavoy » Tue Jun 26, 2018 9:01 am
I found pics back to 2012 that showed up. Net search doesn't reveal anything other than a lot of pissed off people over the 3rd party hosting debacle.
Post by Stan Disbrow » Tue Jun 26, 2018 10:27 am
I just went back in time in the Show and Tell forum and all the PB images I looked at are now showing up. After a dozen or so checks going back several years I figure PB has changed their mind.
notmeu
Post by notmeu » Wed Jun 27, 2018 12:45 pm
:D Woo hoo! That’s good news!
Post by Paul Buhler » Thu Jun 28, 2018 12:56 pm
Went to my Photobucket site, and it appears that they retained a "free" service for those of us who use it minimally; they have tiered pricing for other user needs. Still couldn't link my old avatar, however. Not sure why. Paul
