40c drive sprocket
fundytides
40c drive sprocket
Post by fundytides » Sun Nov 22, 2015 6:00 pm
How do you measure drive sprockets for wear? I thought mine was worn so I started to replace it with another that has deeper teeth. However, it seems that it won't fit because the teeth hit against the roller. Do I have a problem that I'm not awre of? Is it possible that the new (to me) sprocket is off a different model?
Post by Lavoy » Sun Nov 22, 2015 11:40 pm
Check you axle for slop, usually if the sprocket hits the roller, the bearings are shot. The other thing I have had happen is the clutch housing to sideframe bolts are loose, gone, replaced with the wrong ones, or the holes elongated.
lavoy
fundytides
Post by fundytides » Wed Nov 25, 2015 6:19 pm
Checked axle bearings, no slop. Bolts to center frame tight. Tried sprocket again and it did go on, Once in place it does clear the roller by about 1/4". Is that ok? Haven't got the track back on yet as we had some rain and then turned cold so the shoes are frozen to the ground. Supposed to warm up a little tomorrow so probably a little hot water will get me back in business. Thanks.
Post by Lavoy » Fri Nov 27, 2015 1:23 pm
If everything is solid and in place, you should be fine.
Users browsing this forum: No registered users and 35 guests
