420 4spd shift shaft disassembly
- Jimmy in NC
While I have the top of the motor open I figured I might as well fix the shifter up a little bit on the old girl. Popped the top off and quickly removed the shifter lever. I would like to get the shift forks out and look at the tops of them and repair as necessary. The question comes as to the squencing of removal of the taper pins.
Also how do you access the first pin? Do you access it through the shift lever hole (from the top)??
The best I figure is you pull drive the fist pin out on the 2nd and reverse shaft from the bottom, then the other pin out from the top. It seems from there you can access the others from the shaft side of the cover. Clear as mud??
Just trying to make those gears a little easier to find...
Jimmy in NC
Jimmy in NC
- Jimmy in NC
I promised pictures and here they are:
I think this may be some of the problem...
And this pin has been bradded over all it would brad....
And the worn slot.. don't worry.. I'm gonna fix it up!
Shift forks look in fair shape.. I'll be staying away from going any farther..
And one more of the shift forks.
Yes this transmission had serious moisture in it at some point.. but hey.. I think most of them have too!
New pin, bearing, and a pair of snap rings orderd today at mother Deere. A little time in the press and some of my favorite 'red wrench' I'll have the shifter straight and we'll see how it does then.
Jimmy in NC
Jimmy in NC
Hey Jimmy,
I fought a similar problem with my 420 several years ago. It was such that there was a real problem getting some of the gears to work well. 1st groaned a lot and 2nd growled loudly 3rd worked well just to high to do much work and 4th and off to the races. mine must be an earlier model as my shift tower actually has the patern built in and you shift in slots. My shift forks were all good like yours and when I bought the machine there was a 5 gallon bucket over it. the shifter boot was gone and yes there was much water in the tranny at one time. the previous owner had drained it and filled with good dope but the owner before that was the state of Alabama and I don't think their maintenence was so good. I didn't know about this site then and it may not have been around then. I couldn't fine any gears or shafts even from mother deere and had to have the shafts chromed out and ground down to original and then take the gears and sleeve them and bore out to original. Lots of fun. Makes you wonder if you will be able to remember how to put back together when all the parts are back. Also kind of expensive. By the way races from large bearings from over the road tractor rearends make great material to use for the sleeves. Lots of luck.
Bill
Bill
Bill 420c dozer 5 roller
N. E. Alabama
older is better just keep it greased
N. E. Alabama
- Jimmy in NC
Bill-
This transmission is actually pretty good down inside.. the struggles are just with how sloppy the shifter lever is in the transmission. I've got a new bearing on the way and such.. and I'm sure straightening the lever out to where it should be will help more than anything.
Glad you were able to save your transmission..if these old tractors could talk...
Jimmy in NC
Jimmy in NC
Re: 420 4spd shift shaft disassembly
Mr lavoy did not give away the secrets about removing the groove pins from the shafts in order to change bent forks and repair poppet springs but implied it was a pain . Any hints from you masters out there ?
Nickh
Nickh
The ball on the end of the shifter gets worn and causes problems like getting stuck in gear. Unless you are really trying to keep it original you can replace the transmission cover and shifter from a later model with caged shifter and solve the problem. May have to bend it a little for a crawler to clear the steering handles.
Never torn one down that far, sorry.
