pistons
I should be able to get them. Need to know serial number and oversize he wants.
Pistons
Hi, Lavoy.
OK...My friend needs a set (2) pistons, rings, wrist pins and retainers.
He has a styled Deere B, Supposed to be a 1949
Ser # 255003
Here's the kicker...they need to be .090 oversize.
Thanks for any help, good bad or indifferent.
If you find something, I'll have him contact you directly.
Jon K
Ser # 255003
Jon K
Shows $450 for rebore kit, .090, increased compression aluminum pistons.
Oooh. Increased compression. Turn the poppin into crackin! Nice!
What's it increase to. I think they only have about 6.5:1 ratio to begin with.
Unknown, but I would guess a half a point or so.
Laovy
Laovy
Hi, Lavoy,
Just talked to my friend about the pistons. He said he's talked to Steiners, Drapers and several other people about the oversize pistons. They keep promising them in 2-3 weeks, but this is going on for almost a year.
He's down to the point of going .120 over size of even resleeving the block back to standard, IF he can be guaranteed getting the pistons.
So, I guess the question is : are you sure you can get the pistons.
Thank you...
Jon K
Thank you...
Jon K
I can get one set of standard pistons at this time.
