350b bogging out
Gulia116
350b bogging out
Post by Gulia116 » Thu Aug 11, 2016 8:04 am
Im having trouble with my 350b, the machine starts fine, idles, runs through all the rpms fine while parked. But when it comes time to walk the machine will bog out while turning or when you go into a pile. Now it dies out while walking straight on flat ground. It also will bog out while going into a pile first gear wide open. I just changed all the filters drained the tank and reprimed the system, i cant figure it out. Any ideas?
Post by Lavoy » Thu Aug 11, 2016 8:44 am
Make sure there isn't something plugging the outlet from the fuel tank. Weird I know, but been there, done that.
Gulia116
Post by Gulia116 » Thu Aug 11, 2016 8:49 am
I know in my fathers 310c backhoe there is a sock filter at the bottom of the tank, he had similar issues with that and said the sock filter was the cause. Do these machines have a similar filter?
Post by Lavoy » Thu Aug 11, 2016 9:19 am
Mine did not, if it had, most likely would have prevented the problem.
Post by jtrichard » Thu Aug 11, 2016 9:22 am
Search.... mouse turds ..... that will possibly be your answer
amos
With Lavoy
Post by amos » Fri Aug 12, 2016 10:21 am
I'm with Lavoy on this one. Had a diesel Ford 3000 doing similar. Checked everything imaginable and last check was fuel tank; found red shop rag in same. Now the tank is my first check!
77 Ford
Post by 77 Ford » Mon Aug 15, 2016 7:02 am
I'm with the busted governor ring (" mouse turds") too. I would however check the fuel tank first sense it's so easy to make sure you're getting good flow out of it.
JD- 450C track loader
Serial #208336T
Re: 350b bogging out
Post by jtrichard » Mon Aug 15, 2016 9:52 am
Gulia116 wrote: I just changed all the filters drained the tank and reprimed the system, i
I assumed (may be wrong to do so) that with the statement above of the OP that he has fuel flow to the injector pump ..... that's why i said mouse turds
DrLoch
Post by DrLoch » Tue Aug 16, 2016 6:19 am
That would be my guess as well. That is how mine acted when the governor ring failed.
450C Track Loader
291457T
Users browsing this forum: No registered users and 64 guests
