rollers
gregjo1948
rollers
Post by gregjo1948 » Sat Jan 07, 2017 7:13 am
Will rollers interchange between a 1010 and 440? Thanks, gregjo1948
gregjo1948
Post by gregjo1948 » Sat Jan 07, 2017 3:11 pm
Thanks Ralph!!!
Post by jtrichard » Sat Jan 07, 2017 4:45 pm
IF 2010 rollers are the same as 440 ( And I thought there were) It would be ALL 2010 as pre 42000 and after are the same. Also 350s are the same BUT you need to bush the bolt holes
Wilbur
Post by Wilbur » Sat Jan 07, 2017 9:09 pm
While the subject is interchanging parts from 1010 to 440, will the tracks from a 1010 fit the 440?
1959 440 icd 831 loader
1961 1010 dozer
notmeu
Post by notmeu » Sun Jan 08, 2017 11:09 am
yes, the tracks will interchange from a 1010 to a 440. The only difference with the rollers is the bolt sizes, you may want to use some small shim material to make up the difference in the casting hole size.
Post by jtrichard » Sun Jan 08, 2017 11:44 am
The PRE 42000,, 2010 chains will also fit
whiteclipse16
Post by whiteclipse16 » Mon Jan 09, 2017 12:13 pm
1010 pads are 4 bolt, 440 are 2 bolt if you care.
Ben
shinnery
Post by shinnery » Mon Jan 09, 2017 8:22 pm
My original 440ICD at least has four bolt pads, not sure on the other two.
Wilbur
Post by Wilbur » Thu Jan 12, 2017 11:17 am
Thanks for the replies. I tried in vain days ago to reply to posts, just would not do it.
1961 1010 dozer
Post by Stan Disbrow » Thu Jan 12, 2017 1:13 pm
Oh, it does *something* with them. Runs up the Post Count with invisible messages! :P
