hydraulic leak.
hydraulic leak.
I was working my model 93 back hoe on my 450c this weekend and heard a pop noise and have fluid running out of the grill and frt nose piece. Had no tools and was to hot to work in the sun, so I went home. Will head back to the ranch this coming weekend to check what problem could be. Any suggestions as to what to look for?? I'm hoping for hose or lines.
Re: hydraulic leak.
I believe your hydraulic pump is in behind the grill. Probably you've burst a line going to or from it. If it's a pressure line you'll need to have one built but, a return line is low pressure and you can use regular rubber hose. Tractor Supply and NAPA Auto Parts are where I get my high & low pressure lines made.
Users browsing this forum: Al Swearengen and 141 guests
