Secondary Transmission Cooler
CuttingEdge
Post by CuttingEdge » Wed Oct 18, 2017 5:03 am
I have been pounding across a twitch road with my skidder all summer and finally got my bulldozer put back together so I could take care of that issue!
I recently added a Tru-Cool external transmission cooler from Autoplicity ($81) and was wondering if it was really needed. My bulldozer really is not made for stumping or pushing boulders so it was really working. Since I also added a transmission temperature gauge, I would watch the temp climb by 10 degrees (to 140 degrees) then drop as the transmission cooler kicked in and brought the temperature back down.
After grubbing out that logging road for my skidder, I am glad I installed the transmission cooler. It is not for the purists I know, but takes a lot o heat out of the transmission and that is a very good thing.
Re: Secondary Transmission Cooler
Post by Stan Disbrow » Wed Oct 18, 2017 7:27 am
Works for me, too. As it would anyone who ever hauled a trailer all over the place can attest to! ;)
Post by Lavoy » Wed Oct 18, 2017 7:50 am
350 should have had a reverser cooler on it already I think. Might just be in the radiator like a car or pickup, or did you put it in series with it?
lavoy
CuttingEdge
Post by CuttingEdge » Wed Oct 18, 2017 9:58 am
Yeah the 350's have one already, a tiny thing in the base of the radiator.
The instructions on the external one said to plumb it in series with that OEM cooler so that it is preheated in the winter. So I did, which is why I think the oil is running at 130 degrees. I think I could get it cooler if I plumbed it direct to the external cooler, but I am not sure I would want too.
The transmission temp gauge on my skidder puts the "green at 120-250 (degrees F) before it goes to red, so I am thinking 130-140 degrees is ideal?
As stated in the fan post, if I changed to a pull type fan instead of the pusher I have, it might run cooler too. Right now I am pushing warm air from the engine radiator out through the transmission cooler lessening its cooling ability somewhat.
Post by Lavoy » Wed Oct 18, 2017 1:51 pm
I wouldn't want to run cooler. The old rule of thumb to get moisture out of oil used to be minimum of 140 degrees for half an hour. This oil should run at 200 plus all day with no problem, so you are good shape.
CuttingEdge
Post by CuttingEdge » Thu Oct 19, 2017 2:57 pm
Hey thanks for the information.
That is why I put a temperature gauge in it, It is nice to know how warm the reverser is getting.
Users browsing this forum: No registered users and 139 guests
