Gearmatic 8A Winch Parts For Sale
JDCrawlerdog3
Post by JDCrawlerdog3 » Sun Apr 15, 2018 6:08 pm
Gearmatic 8A winch parts for sale:
Gear Cover with Bearing Cap Screw – Good shape - $50.00
Clutch Cover with Bearing Cap Screw and Hydraulic Gland – Chip out at one bolt hole - $75.00
Clutch Bands – Both primary and secondary, need re-lining, bands in good shape - $20.00
Clutch Spider – Two clutch adjusting bolt holes need to be drilled and re-tapped, and two guide plate bolt holes need to be drilled and re-tapped, three clutch band guide plates included - $90.00
Clutch Lever Arm – Good shape, no cracks or welds - $100.00
Master Control – Housing only with cover, no cylinders, has internal lever and shaft - $75.00
Master Control Handle – Splines good. No rubber grip - $75.00
Brake Rod, Spacer Tube, Spring Saddle – Rough but serviceable - $20.00
PM me for pictures.
Thanks.
Andrew
Users browsing this forum: Bing [Bot] and 1 guest
