JD part# T 16261T sprocket for a 420 5 roller, what would it be worth new if they can be found? It sounds from the discussions here that they are no longer available. I may have found one, maybe two and looking to get a handle on the scale of this expenditure to match up with a nice set of 420 chains that aren’t worn just scratched up a little. While Im at it, Is it correct that 350 rollers are acceptable replacement except for bolt hole size?
As I get further into this green and yellow fever, I want to say I appreciate the information available here. A lot of good practicable advice. Thank you.
420 sprocket
- my fathers son
Re: 420 sprocket
$400 each would be my guess.
Yes, 350 rollers work fine, some of the aftermarket ones will hit on the rock guards a little, but easy fix.
