Diaphragm-operated clutch in JD 3325 winch
I have what appears to be a John Deere 3325 winch mounted on my 1973 D-3 Cat. After years of yarding logs with it, a hydraulic oil leak within the left (clutch/brake) case has increased to a rate of about 3 or 4 ounces per hour. Finding the source of the leak was pretty easy. I opened the case and observed the hydraulic oil drip from behind the outer clutch plate while winching-in (clutch engaged). When I pulled off the outer clutch plate, I was surprised to find a fabric diaphragm instead of a piston/cylinder mechanism for compressing the clutch disks together. The exact location of the leak at the edge of this diaphragm was obvious. I figured this would be an easy, inexpensive fix until I started looking for the replacement part. The nearest JD shop found the part number which is T34716, but they have yet to locate one for me. Does any one have ideas where I might find this vintage part?
Re: Diaphragm-operated clutch in JD 3325 winch
I can't help much beyond saying I looked through My Nortrax and found the part number as T34716AM. It shows as: diaphragm, Non John Deere parts, available to order. Send Lavoy an email at postmaster@jdcrawlers.com , he might have a source to get one, or ideas of where to check.
Can you post some pics of how your winch is mounted. I would have figured the deere winch would have been on the light side for a D3.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Thanks for the response. The Nortrax lead looks good, and while searching for that, I discovered another potential source for the part.
Just a follow-up on my old diaphragm-operated clutch problem. I spent about three weeks searching for a replacement diaphragm without any luck. I did locate some of the adjacent steel parts for this old arrangement, and I discovered that there is a variation of the design that substitutes a piston, cylinder and some other parts for the diaphragm. I didn’t really search very hard for the parts to try this option though. However, i came up with the idea of making a 1/8-inch thick, neoprene copy of the diaphragm to fit inside the diaphragm to seal the leak. So far, it seems to be working. I don’t expect this to be a long-term solution, but it was an inexpensive and quick fix. Perhaps this will be useful information for the two other people on the planet who still own one of these odd-ball JD 3325s.
http://www.j-kequipment.com/winch_parts.html
These people are very knowledgeable. They have great selection of parts.
Best regards, Bruce
Best regards, Bruce
Flash forward and few years...The neoprene "gasket" I made, as expected, only got me through one season of logging. I found that the neoprene did not stand up to hydraulic oil very well. I tried a thicker piece of nitrile rubber, and it is still good after two seasons. I think this is a cheap and easy fix.
Users browsing this forum: No registered users and 196 guests
