JD 350 left side track barely drives
jdaniels0206
Post by jdaniels0206 » Wed Feb 13, 2019 2:26 pm
Hello everyone! I recently purchased a JD 350 dozer! The steering clutches were replaced the right side drives and steers perfectly! The left side will brake and barely drive until it’s under pressure then it has no drive! I have attempted
To adjust them by the manual specs but it didn’t improve! Any ideas
Re: JD 350 left side track barely drives
Post by Lavoy » Wed Feb 13, 2019 3:16 pm
Clutch needs to be rebuilt.
B Town
Post by B Town » Wed Feb 13, 2019 3:17 pm
Good afternoon,
You mentioned the right side was rebuilt (I assume this was done by the prior owner). Did they do any work on the left side? It has been my experience in the crawler world that one side is not far behind the other side. If adjusted properly by the manual and no prior work, I would expect the left clutch will need re-built.
Best regards, Bruce
jdaniels0206
Post by jdaniels0206 » Wed Feb 13, 2019 4:23 pm
The previous owner had both sides replaced at the same time !
jdaniels0206
Post by jdaniels0206 » Wed Feb 13, 2019 4:27 pm
Thank you all for the info the caps that go over the compartment were the adjustments take place were left off, when I operate the machine, I can herr sizzling in the left final drive housing and smell something heating up! I figure it’s gotten water down in the housing!
B Town
Post by B Town » Wed Feb 13, 2019 5:16 pm
Water in the clutch housing typically causes lots of corrosion and swollen disks. This will cause the clutch to lock up. Some people buy inexpensive disks to lower the price of their rebuild. The center of the cheaper disks can be tore out and cause problems like you are describing. Either way the left side will need to come apart. Please order quality parts from Lavoy(the proprietor of this site).
jdaniels0206
Post by jdaniels0206 » Wed Feb 13, 2019 5:38 pm
Thank you all I was afraid of this! How do I go about ordering parts from him?
B Town
Post by B Town » Wed Feb 13, 2019 6:20 pm
Email is the best initial contact.
postmaster@jdcrawlers.com
jdaniels0206
Post by jdaniels0206 » Wed Feb 13, 2019 7:30 pm
Okay thank you
B Town
Post by B Town » Wed Feb 13, 2019 8:47 pm
The PO could have put the wrong # of disks back in the clutch pack. One less disk would cause your symptoms, also.
jdaniels0206
Post by jdaniels0206 » Wed Feb 13, 2019 9:46 pm
B town
Does all 350’s vary on how many discs are required? When I’m reading seems they all are required to have the same on each side? Or was you just saying he may have just like left one out not knowing what he was doing?
B Town
Post by B Town » Thu Feb 14, 2019 5:57 am
May have accidentally left one out. I have read a thread about that very situation. Doubtful here, since both sides were done. Keep us posted.
jdaniels0206
Post by jdaniels0206 » Fri Feb 15, 2019 8:09 am
One more thing the power steering cylinder on the right side works perfectly when you pull back on the lever, it goes back smooth and I can feel the hydraulics kick in! The cylinder on the left is tighter and doesn’t go back as far as the one on the right. What would cause this?
Users browsing this forum: Google [Bot] and 129 guests
