How hard is a ring gear replacement? I galled mine up today. Not major damage but the starter is spinning/ grinding in that one spot.
If I had crank it past I can get it to start, but if the flywheel stops where the damage is the starter won’t engage
I have a shop manual on order, but want to know how bad I messed up
450e flywheel
Re: 450e flywheel
You will need to pull the engine to get to the flywheel. Not hard to change the ring gear itself once you get the flywheel off the engine.
Users browsing this forum: No registered users and 106 guests
