The next victim part II
The other post was getting kind of long, so decided to start a new one.
This is a pic of the partially assembled power train sitting in the stand.
Oooh. Nice stand!
The thing is beginning to look somewhat familiar.
Oooh. Nice stand!
No, they are just zinc plated. I do not use unplated fasteners unless unavoidable. The fasteners will get painted when I overshoot the whole thing. I need to get a lot more parts on before I do that.
I personally do not mind the look of unpainted fasteners, but this yellow is so hard to match from piece to piece as they get painted, that another coat is the only way to make it look good.
I like the unpainted hardware myself. Whenever I refinish metalworking machinery, I always go with unpaint hardware. Big difference is that machine tools stay indoors and a little Boeing T9 coating goes on everything to protect against any condensation.
I'm up to the point of reassembling the major parts of my crawler and was wondering if most folks just prime the parts and finish coat when assembled or finish paint the parts and second coat everything when assembled. The coverage is sure better if you go with the later method.
Well, my painting method is rather poor by comparison to most folks. I put the thing together less the tin bits, wire brush what's there (old paint and rust), then put on two coats of new paint - with a brush. I don't even bother with primer, as machine enamel tends to do well as it's own primer in my experience.
The only bits that get sanded and spray painted are the tin parts, and that's because they're actually smooth and would show brush marks.
My thinking is that these are tractors and the paint exists to keep them from rusting away too quickly.
Then, too, I don't make up show stuff. Oh, it might go to a show now and again, but I have this tendency to keep right on using my old iron to do work. Perish the thought!
As I fix the leaking cooling system in my 420c, I'm going to get loose with the can of paint and brush. My intention is to paint where there is no longer paint, but I'll probably wind up painting most of it in the end.
- lastchancegarage
Awesome project Lavoy, this is better than the discovery channel...hmmm...wonder if they ever thought of showing something like this? Thanks for the shots.
1959 JD 440 ICD dozer
195? ATC GT-25 dozer
Question about the Tachometer in the photo
Is the tach shown in the dash photo the current Deere service part? If not where is it from?
Users browsing this forum: No registered users and 46 guests
