Does any one have a source for 350B transmission parts? Need shaft for 1ST AND 4TH SHIFT John Deere PN T20880.
Thanks in advance.
Chester
Need Transmission part for 350B JD PN T20880
Re: Need Transmission part for 350B JD PN T20880
Check here with Lavoy first because he sells parts for these JD machines. If he doesn't have anything I would Google your area or state and see if there is a good salvage company near you. Otherwise I have used PB&H in New Hampshire. ( 1-888-588-3005 ) Or you can try the company I use here in Missouri which is Zimmerman Tractor. ( 1-573-378-7210 ) Both of these companies have a lot of John Deere salvage equipment. PB&H will have a line on some aftermarket parts as well. Try Lavoy first because he may know some place better than who I have mentioned.
Thank You for the info. I did find the part I needed from local junk yard.
Thanks Again
Chester
Thanks Again
Chester
