40C fluid level
40C fluid level
Where is the oil check for the trans/diff on a 40C? I assume there is a plug to fill and check the fluid. Also are these 40s a positive ground 6 volt system? thanks, gregjo1948
Re: 40C fluid level
Fill is under your right heel, drain in on the opposite side underneath.
Yes on positive ground.
Re: 40C fluid level
Thanks Lavoy. I found it already. I just got this little guy home and it had a bunch of leaves bunched up around the fill plug. I haven't had a green dozer in years and forgot how simple they are. Even though it has 2 cylinders, it doesn't sound anything like my Harley.
Re: 40C fluid level
Nope. Not a Harley.
JD is 2 cyl out of 4 when it comes to the firing. Harley is 2 cyl out of 5. Quite different sounds.
Nope. Not a Harley.
Re: 40C fluid level
I have been told that Harley patented the sound/noise their 2 cylinder engines make.Stan Disbrow wrote: ↑Tue Sep 15, 2020 4:34 amHi,
Nope. Not a Harley.
Users browsing this forum: No registered users and 142 guests
