Would the hydraulic pump on front of engine on a 350 straight loader work on a 350 straight dozer considering
the difference in GPM.
Hydraulic pump on 350 loader/dozer
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
Re: Hydraulic pump on 350 loader/dozer
I would say yes. The loader pump will pump more gpm than the dozer pump but, I don't see why that would matter. I'm sure Lavoy will give you a definite correct answer.
Bolt up yes, dozer function will speed up so harder to control blade for smaller movements, only thing I can think of.
Thanks, I might give it a try, I'll you know how it works. P
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
