Is there a source for new or aftermarket parts to rebuild the pivot points, pins and lever arms for a 350B loader arms? Dealership parts still available?
Bennett
350B loader Arm bushings, pins and lever arms rebuild
JD 350B w/ 4 in1
JD 4520 Compact Utility
JD 1025R Sub Compact
Cat 303.5 Mini Ex with Bushmaster Brush Cutter
Soilmover Dirt Pan
Soilmover Dirt Pan
Re: 350B loader Arm bushings, pins and lever arms rebuild
The last time I got parts for a loader as in boom and bucket parts was about five years ago and they were from Deere. I would check with a Deere industrial dealer to see what's available. They may still have some of the parts available.
I just checked with Deere, and the only parts available now are the bushings and washers. most have been obsoleted. Looks like I will have to fabricate these parts.
Thanks for the Info!
I love this site and all the kind people that are on it.
Bennett
Bennett
JD 350B w/ 4 in1
Soilmover Dirt Pan
Soilmover Dirt Pan
What would be a good grade of steel to use for fabricating pins?
Any good steel with enough carbon in it to heat treat.
Users browsing this forum: No registered users and 155 guests
