JD1010 Water pump
JD1010 Water pump
can anyone tell me if there is a difference between gas and diesel water pumps on a john deere 1010 crawler? I see some listed on ebay but says for gas only but in manual I Don't see any difference.
Re: JD1010 Water pump
Good morning,
The on line parts catalog shows separate pumps for gas and diesel on early serial numbers and one pump for both starting with serial number 21901. So it looks like depending on your serial number the answer could be yes or no.
The parts catalog index calls them: Chamber, turbulence (pages 42 and 43). Here is a link to the catalog so you can review the pump info. https://partscatalog.deere.com/jdrc/nav ... ment/77299
Good Morning Jim thank you for the reply mine is 15859 so I guess I have the different ones and am looking at a rebuild kit
