THROW OUT BEARING
jg002305
THROW OUT BEARING
Post by jg002305 » Fri Feb 24, 2023 7:17 pm
DOES THE STEERING THROWOUT BEARING HAVE TO BE PRESSED ONTO THE CARRIER.
THE CARRIER THAT I HAVE SEEMS TO HAVE THE 1/8 INCH RIDGE WORN DOWN, IS THAT POSSIBLE.
IF IT IS NOT PRESSED ON WILL THAT CAUSE A PROBLEM SINCE THE CLUTCH FINGERS ARE IN CONTACT WITH IT AT ALL TIMES.
THANKS FOR ANY THOUGHTS AND HELP
Re: THROW OUT BEARING
Post by Jim B » Sat Feb 25, 2023 12:37 pm
The throwout bearing should be pressed on the collar so it pulls away from the pressure plate fingers when the steering handle is released, and the clutch is engaged. If it is just floating around it could cock out of true and cause the steering engagement to vary, besides continuing to wear the collar away. Adjustment will be difficult if you can't be sure the bearing is always seated. Lavoy may have the parts you need. He prefers people contact him directly, not via a post or the PM system. You can call Lavoy at 701-361-1006 during CST business hours or by email at (postmaster@jdcrawlers.com).
Post by Lavoy » Sun Feb 26, 2023 9:42 am
Plenty of them on hand.
jg002305
Post by jg002305 » Mon Feb 27, 2023 5:44 pm
THANKS JIM B
GREAT INFORMATION
LAVOY
WILL CONTACT YOU SHORTLY
JG002305
Users browsing this forum: No registered users and 73 guests
