Devcon for sprocket/final drive shaft repair
a_man
Post by a_man » Mon Aug 22, 2022 8:46 am
Howdy all, I have a crawler where the splines in between sprocket and final drive are worn and the threads that hold the sprocket nut on are shot.
This is actually a case 310c crawler, but my research on spline repair for crawlers led me here hope that is ok.
viewtopic.php?f=1&t=3118&p=14520&hilit=devcon#p14520
I wondered if the deere parts kit has any special directions or if I should just grab the 1 pound kit of plastic steel of amazon and go for it (Or should I spring for titanium?)
Got some pics of it in post 19 of this thread on HEF, will copy them over when I get home, but they are not showing up now.
https://www.heavyequipmentforums.com/th ... now.93565/
Thanks a bunch --Andrew
77 Ford
Re: Devcon for sprocket/final drive shaft repair
Post by 77 Ford » Fri Sep 02, 2022 8:04 am
I'm sorry I don't have anything to add but I went and read you thread over on HEF and man on man have you got a project. I wish all the best!
Maybe bumping will get Lavoy over here, he's actually used the stuff in question.
JD- 450C track loader
Serial #208336T
pop pop
Post by pop pop » Tue Oct 17, 2023 4:22 am
hi A-man, i have used the devcon steel putty and it is a very good product, but it is not going to hold up (fix) your problem.
Post by Lavoy » Wed Oct 18, 2023 8:11 am
I'm assuming you mean between the hub and the axle? If so, I'm also assuming you have a 3 roller crawler?
Users browsing this forum: No registered users and 128 guests
