Rear PTO and 3 Point hitch questions
Sapmaster
Post by Sapmaster » Mon Nov 01, 2021 3:47 pm
Hello,
I would like to know what John Deere crawler models have a rear PTO and 3 point hitch hookup?
Does the rear PTO have a lever operated disconnect?
Was a rear PTO standard on any crawler model (i.e. 440c, 40, etc.)?
How hard is it to add 3 point hitch hookup?
Buckhorn
Re: Rear PTO and 3 Point hitch questions
Post by Buckhorn » Mon Nov 01, 2021 4:55 pm
My 420 has a rear PTO lever, but I don't have a PTO installed.
E.Huffman
Post by E.Huffman » Mon Nov 01, 2021 4:55 pm
Correct me if I am wrong some one but i believe the mc 40c 420c 430c and 440 had or could have pto and 3point from factory. IU have a 420c loader but it does not have 3 point or pto because it was more of an industrial crawler not an ag crawler. Yes the pto has a lever just like the 2 cylinder tractors.
gus
Post by gus » Mon Nov 01, 2021 5:28 pm
I put a PTO on my 420. Simply remove the cover where the PTO goes and bolt it on. I did put new seals in the old unit before putting it on and generously lubed it too.
fundytides
Post by fundytides » Mon Nov 01, 2021 7:09 pm
The 40c as well had provision for 2 PTO shafts on the rear of the transmission. One for Standard PTO attachment providing 560 rpm and one for auxiliary equipment requiring higher speed and provides engine speed (1850 rpm) for such things as winches and hydraulic pumps. I think MC crawlers had a similar arrangement but not sure
Post by Lavoy » Tue Nov 02, 2021 7:49 am
All two cylinder crawlers either had a PTO, or the ability to add the PTO attachment with the internals already installed in the transmission from the factory, standard. There is a lever to engage the PTO on all of them. 3PT hitch was an option on 420 through 440, and could be field installed on 40s after serial number 62,263. Not difficult to add one, just need to find the factory unit and bolt it on.
Post by Lavoy » Tue Nov 02, 2021 7:52 am
Additionally all 1010 crawlers came equipped standard with the ability to add the PTO attachment. 2010 crawlers were more of an involved setup, but were available with a PTO as well, but somewhat more of an option than the earlier crawlers with the exception of the Ag crawlers which I believe were all capable.
Sapmaster
Post by Sapmaster » Tue Nov 02, 2021 9:48 am
Where are the best places to look for factory 3 point setups?
What is the average price for a 3 point setup?
Post by Lavoy » Tue Nov 02, 2021 12:09 pm
No real specific place to look, here is a good as any. Price will be all over the board, but buying something incomplete at a cheap price does no good, then you are parts shopping.
I have a customer that has one for sale, if you are interested, give me a call and I will put you in touch with him
briancady413
Post by briancady413 » Mon Sep 07, 2026 2:19 pm
I am interested in installing a PTO and 3 point hitch to a 1968 JD350 loader (with 730A backhoe now mounted), to drive a ditch-clearing rotary-plow-type implement.
How much might these cost?
Where might I get them?
Brian
Post by Lavoy » Tue Sep 08, 2026 9:44 am
Very expensive, very hard to come by, and you would need a loader valve that has an auxiliary circuit to run the 3PT hitch.
briancady413
Post by briancady413 » Tue Sep 08, 2026 1:37 pm
Hi Lavoy,
Thanks for your response.
3. I have an auxiliary valve.
2. Do you, Lavoy, or anyone else have parts toward this? I guess I need the PTO shaft, and the links and the cylinder for the 3 point hitch.
1. Do you or anyone else have any vague idea how much; how many thousands approximately, this might cost?
I will check to see if I have the PTO cutout heel lever.
Brian
Post by Stan Disbrow » Wed Sep 09, 2026 7:27 am
On a 350, you would need to have that in/out lever for a PTO. The lever operates the internal drive parts which are not inside the trans if the lever is not present.
briancady413
Post by briancady413 » Thu Sep 10, 2026 7:27 am
Thanks, Stan,
The PTO engaging lever is present and seems to operate.
Post by Stan Disbrow » Fri Sep 11, 2026 6:52 am
All right! Now it is just the easy part of finding the rest of the external parts. Easy meaning you don't have to get into the transmission to add those bits.
Users browsing this forum: No registered users and 100 guests
