Case closed folks…
I ended up buying a used but in good condition reverser for a fair price. It was a little less labor and about 1/2 price of a rebuild.
It came out of a B model, but with just some slights mods it fit and works well inside of the C model. Had to plumb the return line thru a hydraulic cooler fitting for the steering clutches and also remove the shaft and linkage used for the foot brakes. On the upside I’ve got two really nice inspection holes into the transmission chamber to check input coupler if it ever snaps.
I also used my C model control valve.
As always thanks for all the input and knowledge.
350C Power Issues
- Jason37756
gaz_whitaker67
Re: 350C Power Issues
Right, Jason37756, mine went the other way with a slipping clutch on an old Triumph I was doing up in the garage. I bought a second-hand clutch basket that looked lovely and cost nowt... and it was slipping again within a month, so I ended up stripping the lot and doing it properly with new plates. Cost me alot more in the end, and wich I definately moaned about to the missus. Not the same beast as your reverser obviously, but that's how it panned out for me.
Users browsing this forum: No registered users and 20 guests
