bulletpruf
Post
by bulletpruf » Sat Jul 25, 2026 8:24 pm
'67 350 straight. Realized today that the idler on the right side was held on with a regular 3/4" bolt and no grease fitting, so it hasn't been getting greased.
The bolt is NLA new, so I'll have to source a used one.
A few questions -
-Can I just remove the current bolt and install a correct one? Or do I need to jack up the front of the machine and support it? Do I need to do anything to keep the idler and track from sliding off?
-How can I tell if the idler is junk?
bulletpruf
Post
by bulletpruf » Sun Jul 26, 2026 7:02 pm
Disregard. For some reason, someone put the bolt with the grease fitting on the inside instead of the outside. I'll swap them around.
Post
by Jim B » Mon Jul 27, 2026 4:56 am
Make sure the shaft was drilled completely through. some might only be drilled from one side. Just something to check. Pull the bolt out and run a wire in or pump some grease in the fitting and see if it comes out the bolt hole.
bulletpruf
Post
by bulletpruf » Mon Jul 27, 2026 7:31 am
Jim B wrote: ↑Mon Jul 27, 2026 4:56 am
Yeah, someone mentioned that in the 350 Facebook group. I'll check that.
dabear3428
Post
by dabear3428 » Mon Jul 27, 2026 9:54 am
bulletpruf wrote: ↑Sat Jul 25, 2026 8:24 pm
A few questions -
and i thought you were going to send that bolt to your buddy down south with a lathe to drill it out for you lol
John Deere 350 straight
bulletpruf
Post
by bulletpruf » Mon Jul 27, 2026 10:02 am
dabear3428 wrote: ↑Mon Jul 27, 2026 9:54 am
A few questions -
That would work, too. But I already have a spare on the way from Danne Moore in Vermont for $10 + shipping.
thanks
bulletpruf
Post
by bulletpruf » Mon Jul 27, 2026 10:03 am
I found some pictures of the shafts for sale online and none mention that it's drilled completely through. Given how it's constructed, I strongly suspect it's only drilled on one side for grease.
Whitfield77
Post
by Whitfield77 » Sat Oct 24, 2026 4:33 am
Jim B wrote:Make sure the shaft was drilled completely through. some might only be drilled from one side.
Jim B, not sure I'd go that far with the wire test... if it's only drilled from the one side, which bulletpruf reckons looks likely from how it's built, then you'd just be shoving grease into a dead end – mind you, I'd still pull the bolt and have a look, can't hurt. To be fair, on my old MGB bits I've had a few "drilled right through" parts that turned out to be nothing of the sort, so I'd trust a bit of wire over the photos, mate
