420 starter knob
420 starter knob
Post by Ray III » Sat Sep 15, 2007 1:27 pm
Is this what it's supposed to look like (just like the choke knob)?
I'm restoring the instrument panel area.
Starter knob
Post by JD440ICD2006 » Sat Sep 15, 2007 2:04 pm
That would work if the threads are the same as the shaft, but it does not look original to me. I think the shape is different, let's see what others say.
Post by Ray III » Sun Sep 16, 2007 5:39 pm
My father also does not think it is original, the one that was on it was more of a toadstool shape if you imagine one with a flattened top. I was going to replace it because I melted it in paint thinner and thought it was ruined, but it looks all right after drying out.
No one knows?
Post by Lavoy » Sun Sep 16, 2007 6:54 pm
That is not the correct knob as far as originality. It most likely is the correct part number, it is just a change in suppliers and no attempt was made to retain the original look. I think I have or will have the correct knobs available shortly.
Post by Ray III » Mon Sep 17, 2007 10:07 pm
Thanks Lavoy, I kept the knob I have for now until I get to the bottom of it.
Do you have vintage water temp gauges? I'll e-mail you sometime if you miss this post.
Post by Lavoy » Tue Sep 18, 2007 9:10 am
The OEM gauges have gotten pricey recently, over $100. I know a guy that is making new ones, but not much cheaper. Aftermarket gaues that say Deere, but are not the correct scipt and face style are readily availalbe, and fairly reasonable. Aftermarket that is a generic gauge I normally have on hand.
Users browsing this forum: Bing [Bot] and 338 guests
