1010 Fuel Line
1010 Fuel Line
Post by wwattson » Tue Sep 18, 2007 8:09 pm
Does anybody happen to know the size and material for a 1010 fuel line? The parts book only lists a Deere part number long gone. I'm guessing 1/4" and copper but I'd like to get back as close to stock as practical. Thanks.
Post by Lavoy » Tue Sep 18, 2007 9:22 pm
Bill,
I think it is actually steel line.
Post by wwattson » Tue Sep 18, 2007 10:08 pm
Do you think it was 1/4" Lavoy?
Post by Lavoy » Wed Sep 19, 2007 7:38 am
I thought it was, unless 5/16" is a common size. As far as line, I would use brake line, it is plated I think.
Post by wwattson » Wed Sep 19, 2007 8:34 am
I'm thinking you're right on 1/4" Lavoy. The surviving fittings from the original line don't seem like they would be big enough for 5/16" tube and that isn't that common of a size.
While we're on tube sizes, is the pressure side hydraulic tubing 5/8"? That's what I was planning on using because I have the correct flaring and bending tools for 5/8" as that's the size used for my other "red" project. It looks like 5/8" from all the descriptions in the parts book but it's still kind of a guess because it only lists old Deere part numbers and not sizes.
Post by Lavoy » Wed Sep 19, 2007 6:25 pm
Bill,
Not sure on that one, although that is a common size on these things.
sbarr
Post by sbarr » Thu Sep 20, 2007 5:49 pm
Yup 1/4" I just made up a new one for my 420 out of stainless,copied an original one to keep the factory look but shinyer
58 420c w 61 blade and 3pth and pto,57 420c w loader,48 D,48 M,Allis D-15 and a Super Duty to haul these!!!!
Post by Lavoy » Fri Sep 21, 2007 8:42 am
You know what, now that Steve says that, I think the 1010 is 5/16 or 3/8, I know it is definitely bigger than a 420.
Post by wwattson » Fri Sep 21, 2007 12:28 pm
It's 3/8". It occurred to me that although the fuel line wasn't listed in the parts system anymore, the associated fittings probably were. SCORE. They're all 3/8" OD fittings both side of the strainer. Somebody switched mine out for 1/4" at some time but I'm sure they should be 3/8".
As to the hydraulic line, I'm going with the 5/8". The Correct Police may have to issue a ticket at some point in the future but it's just too much money to buy the tooling to do a different size and it is large enough to support the sort of volumes the pump is capable of.
Users browsing this forum: No registered users and 294 guests
