440ICD Starting
Post by Lavoy » Wed Oct 18, 2006 12:39 pm
Block heater for a 2-53 is a spefic item. I would check with a local Detroit dealer, or at least a good parts house. The one you are referring to I would guess is the drain plug heater for the horizontal two cylinder tractors only.
As for fuel blends, up here most of the stations go to 50/50 at least. If you can find it, Koch has a #2 fuel that is called P40 I believe. I run it frequently in the pickup when the temps get real cold. It is rated to -30 I believe, but is still a #2 fuel. Cenex has something similar called Wintermaster, I have run it many times as well. Both can be hard to find, they are usually a few cents over, so most people just run the blend. I don't like the blend, it usually costs you a couple of miles to the gallon, and a little bit of power as well.
Tim_in_IA
Post by Tim_in_IA » Wed Oct 18, 2006 1:53 pm
Lavoy wrote: The one you are referring to I would guess is the drain plug heater for the horizontal two cylinder tractors only.
Yes I was referring to the gas engine. So you just remove the drain and put that in? No other freeze plug locations? I guess that works. :)
1958 440ic with blade
Post by Lavoy » Wed Oct 18, 2006 8:17 pm
No, the heater you are referring to is most like to fit ONLY the Waterloo built two cylinder tractors. There was never a factory listing for a block heater for the Dubuqe built two cylinder engines. Most likely you will see them with a tank heater or hose heater, but hose heaters do not work on them very well.
I have figured out a way to get a block heater in the freeze plug behind the carb. It is a real tight fit, but works great.
Users browsing this forum: No registered users and 197 guests
