Broken Crossmember to Reverser Bolt - How to Fix?
- jimmydiesel
Re: Broken Crossmember to Reverser Bolt - How to Fix?
Ya looks like only the weld nuts in that size.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
440 ICD 831 Loader
440IC 831 Loader
bulletpruf
- 430 crawler
The weld nuts were delivered and I'm not too impressed. There's only three threads to engage, and that doesn't look like enough to me.
My YouTube channel - https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Use some flat bar to make some. Cut the pieces a couple inches long of the appropriate width to set on the rail flange, thickness based on the bolt size. Drill and tap the size/thread hole you need in the center. If you want them to float, use some sheet metal pieces to tack to the frame rail and bend them over the "nut" you made. Where you tack them will determine the float you have. The flat bar nut is long enough to react on the frame when you tighten them, the clips only have to keep them in place to start the bolts.
bulletpruf
- 430 crawler
Thanks. That will work.Jim B wrote: ↑Wed Jul 01, 2026 11:11 amUse some flat bar to make some. Cut the pieces a couple inches long of the appropriate width to set on the rail flange, thickness based on the bolt size. Drill and tap the size/thread hole you need in the center. If you want them to float, use some sheet metal pieces to tack to the frame rail and bend them over the "nut" you made. Where you tack them will determine the float you have. The flat bar nut is long enough to react on the frame when you tighten them, the clips only have to keep them in place to start the bolts.
Users browsing this forum: Google [Bot] and 100 guests
