Crack in housing on 440 ICD
Post by Ray III » Sun Feb 10, 2008 7:43 pm
I looked at 270210255242, they say it came off a 2010.
Aren't they interchangeable side to side if all ears are drilled?
shinnery
Post by shinnery » Mon Feb 11, 2008 12:26 am
No the title of the auction indicates it is for a 40-420. In the description of the item he mentions the picture of the 2010 tractor that he will be junking in the near future.
AFAIK the difference in left or right side is which way the brake rod comes out of the housing and which side of the top cover the barrel plug is tapped into at the top as it has to be on the correct side to adjust the brake band?
I have no way of knowing if a housing for a 420C will work on a 440IC.
Stormy
Post by Stormy » Mon Feb 11, 2008 7:21 am
Well for what it is worth with your comments I was able to convince the other guy we should replace it. Does anyone know for sure if the 420 will fit the 440? Also Lavoy were you able to find out which one you had?
AJ
440 ICD
CELSESSER
Post by CELSESSER » Mon Feb 11, 2008 9:19 am
Stormy,
The steering clutch housing is the same part number (AM 3520T)
for 40,420,430,and 440. The casting was the same for both left and right, they were just drilled and tapped differently. The bosses are there, I suppose it would be possible to drill and tap it for the other side and plug the holes you aren't using- anyone ever try that?
Chuck
CELSESSER
Post by CELSESSER » Mon Feb 11, 2008 9:25 am
Stormy,
Also the housing on ebay is a left. The brake rod and the brake adjusting bung face forward.
Chuck
Post by Lavoy » Mon Feb 11, 2008 5:28 pm
Stormy,
I am gone for most of the week, send me an e-mail and I wiill check when I get back.
Users browsing this forum: No registered users and 47 guests
