John deere MC
- gregjo1948
John Deere MC
Did the MC come originally with that type of track pad and 2 hydraulic cylinders to operate the blade? Greg
- 40C crawler
No the blade is not original. I believe it is of a 40 or later. The owner I bought the tractor from bought it with no blade. He got the blade at a auction and put it on after the fact. It has not been on there long.
The tracks I have no idea. I know one thing someone has definitely been in the finals before. Seeing as it is a pieces now. I have some more picks I will post up. I am curious to know.
1951 JD B
1952 JD MC
1952 JD MC
The blade is a #62 from a later crawler like 420 or 430.
MC's after 19,000 something came with that style pad.
- 40C crawler
- 40C crawler
- gregjo1948
John Deere MC
Thanks, Lavoy, for info about the blade and track pads. Greg
- 40C crawler
- 40C crawler
What happens is the pinion bearings go out, and people keep running the crawler. I have welded some like that, and left many more alone. On an MC, probalby not a big deal unless it is beginning to perforate.
- 40C crawler
I see that make sense.
I saw somewhere on here measurements for the steering clutch disks, but can't find them now. I have mine all dissembled and am trying to figure out at what measurement they should be replaced. My Rh clutch looks like it saw some water once, little rusty. Metal Plates measure new and clutch discs measure just below the new measurement callout in my manual. Only problem the crawler ever gave me is I think I slipped the Rh clutch once, so I want to give it the proper attention while apart. I was pushing brush and caught a little stump I the center of the blade. The Lh track spun and the Rh let out a little growl and did not spin. Assuming it was the clutch slipping.
Is there a measurement for replacement?
1951 JD B
1952 JD MC
1952 JD MC
- 40C crawler
Going to have get my welding skill sharpend up! The milling that the clutch did at some point in this crawlers life is cracked along the lower part of the goudge. This should be fun...atleast I have nothing to loose it is cracked already. Hopefully the crack already being there will help relieve some of the stresses.
Think I may have to preheat this one on the grill for a while.
1951 JD B
1952 JD MC
1952 JD MC
They do tend to draw a lot when you weld them, that is a lot of bead. Preheat a bunch with a big propane torch, or set it on some charcoal, whatever you can to put a lot of heat into prior to welding.
- RacinJason
- 430 crawler
John Deere MC
Hi, Yellow, That is a really nice looking MC. A lot better than my recent 40C purchase. I'm commenting because Lavoy mentions your dozer blade is probably a 62 from a 420. It appears similar to the one on my 40C, but they did a real butcher job on the hydraulic system.
- 40C crawler
Users browsing this forum: No registered users and 43 guests
