Well tonight the seal on the side I had apart previously finally gave up...Any ideas where I can get a O-ring and seal kit for the track adjuster for my 2010... gonna do it right this time, and only seems to throw track at the most inconvienant of times...lol....with all my friends and family watching!!!
Any pointers on cleaning the tube without damaging it would be appreciated. Thanks in advance.
2010 track adjuster seals....grease coming out bypass hole.
PM Lavoy.... as for cleaning wire wheel on drill or grinder just knock the heavy chunks off the bore is where the seal is the outer is just a dirt seal .... and for you guys back in the swamp land I would think about drilling a hole about a inch from the rear of the tube and putting a zert in there so you can pump the dirt water and other crap out every so often as the dirt seal is not going to do much on a shaft that rusted and it will keep the tube from rusting to a point where it wont move some guys have had that happen just a though
