1957 420C seized - photo journey
emmett
Re: 1957 420C seized - photo journey
Post by emmett » Wed Nov 10, 2021 7:42 am
Next step is to install the clutch disk and pressure plate.
I don't see how it can be done without the disk centering tool, but we had one.
420C Crawler 1957 w/ blade & army 6x6 winch
emmett
Post by emmett » Wed Nov 10, 2021 7:46 am
Big step was to mount the engine on the bell housing.
Two guys needed. One navigating the engine block onto the drive shaft, one flying the engine hoist altitude.
Looks good.
emmett
Post by emmett » Wed Nov 10, 2021 7:48 am
On with his head!
emmett
Post by emmett » Wed Nov 10, 2021 8:00 am
Starter, battery, carb, governor, re-installed.
We wanted to start it up before we glued more components on, such as the radiator, etc.
Then the distributor should be easy right?... Nope. This is where I learned the previous overhaul was done WRONG! The internal timing was previously 180' out. I guess the guys who rebuilt her before didn't have the distributor timing tool. The distributor was mounted with the coil wire connector next to the engine block.. but it should be totally outboard of the engine. I looked at my initial pics and re-installed the distributor to match this wrong orientation. Needless to say, the engine would not start... but I figured it out when I found the ONE pic in the John Deere manual showing the distributor with the coil-wire connector outboard. Next day, turned the distributor, and it STARTED RIGHT UP! This is a happy moment and the proper 4-letter words were joyously emitted.
Here she is, ready to start (when i snapped the pic, the distributor is 180' out of alignment)
emmett
Post by emmett » Wed Nov 10, 2021 8:07 am
Now with the generator, water pump, and radiator installed.
She starts easy and runs smooth.
Thanks for the parts Lavoy.
This is the last pic of the "Photo Journey". Thanks for watching.
Users browsing this forum: No registered users and 45 guests
