Is there a way to adjust the break on my 350C, when you push on the pedal it has no affect on the machine at all. Not sure if the break band is toast or if it can be adjusted.
350 CE Wide Pad Questions / With Pictures ** NEW UPDATE
IF it steers nice (as in the track stops when the lever is pulled) then the brake bands are OK its between the pedal and the steering housing ... YOU REALLY NEED a service manual if you don't have one the steering/brake adjustment are petty complex and have to be done in a specific order
Users browsing this forum: No registered users and 86 guests
