450 JD steering clutch shaft removal
Hey guys need help removing steering clutch and brake shaft .I Have removed pinion shaft to bull gear. But can not pull next shaft out, it has a 3/8-16 thread in end of shaft. Pulled on it with puller but did not move. Are their any ring locks on it I have not seen or does it just pull straight out. This is a straight John deere 450 crawler.
Thanks for any help. Scooty
Look here page 5 http://www.jdcrawlers.com/messageboard/ ... c&start=60 if you are pulling both clutches (you may have to pull both) then you can use a brass rod or soft galvanized water pipe 3/4 or 1" from the other side to help drive it out that what Dennis (crawler123) had to do on his
jtrichard wrote:Look here page 5 http://www.jdcrawlers.com/messageboard/ ... c&start=60 if you are pulling both clutches (you may have to pull both) then you can use a brass rod or soft galvanized water pipe 3/4 or 1" from the other side to help drive it out that what Dennis (crawler123) had to do on his
Thanks for the information
Scooty
Re: 450 JD steering clutch shaft removal
there are no locking pins, clips or any thing else, I used a slide hammer. support the clutch assembly and get after it, be aware that there is a spacer on the end of that shaft.scooty wrote:450 JD steering clutch shaft removal
450 dozer
