1010 diesel compression question
c.lane
Post by c.lane » Wed Jun 10, 2015 7:18 am
I have the following compression on cylinders 1-4: 360, 250, 0 and 305. The machine lost power last winter while plowing snow. Air pressure applied to that cylinder shows leakage to the crankcase. Considering the general condition of this machine and my need and desire to get it running, can I afford/find parts to just get the bad cylinder repaired? A major overhaul seems futile and crazy to me! Thanks.
Post by Tigerhaze » Wed Jun 10, 2015 10:48 am
The problem is that the 1010 uses a deck sleeve, so if the issue of lack of compression in that cylinder is in part because of the cylinder wall scoring then you may need to get a new deck sleeve, and they are not cheap.
Post by jtrichard » Wed Jun 10, 2015 5:34 pm
need to pull the head and pan and see just what you have wrong .....YES the sleeve deck is pricy but at least yours is 1010 diesel it uses the same sleeve as 2010 gas they are made aftermarket :) :)
whiteclipse16
Post by whiteclipse16 » Thu Jun 11, 2015 5:27 am
Yep you can find the deck but very pricey. $700+ I believe is what we paid for ours a year or two ago. That was from Deere though.
Ben
vailvalley59
Post by vailvalley59 » Thu Jun 11, 2015 6:03 am
I have a used sleeve deck for 1010 diesel--good condition --was bought by mistake when working on 2010 diesel. Let me know if you find you need one--thanks
2010 diesel loader, IH 886, Cat 1947 D4 dozer, IH 966, Ford 7000, IH 2500, IH 706 and other toys
Users browsing this forum: No registered users and 47 guests
