Hello all
I ran my jd440icd out of fuel. When I added fuel and got it running ithe engine did not rev up to normal operating seed. I noticed that the fuel pump was leaking. Could this be the issue? Is there a way to hook up an electric pump? Is there any one that has done it already?
Engine does not have enough power
- 430 crawler
53 series Detroits will suck air at the fuel pump seal and run like crap ....if the pump is leaking then you may be getting air ....put a new shaft seal in they are a very easy pump to work on
Users browsing this forum: Google [Bot] and 49 guests
