420c transmission flush
woodsnwater
Post by woodsnwater » Fri Oct 30, 2015 11:26 am
New member here. I recently bought my first crawler and the trans gear oil is milky white. Can I flush it with diesel or kerosene? I mean actually drive it around a little to really clean it out. I was concerned about the clutches.
Post by Lavoy » Fri Oct 30, 2015 2:34 pm
Either will work, I wouldn't drive it a lot or any heavy load. Clutches are isolated from trans, no harm.
woodsnwater
Post by woodsnwater » Fri Oct 30, 2015 3:22 pm
Shows how much I know. :D Thanks
Post by Lavoy » Sat Oct 31, 2015 9:15 am
No problem.
CCWKen
Post by CCWKen » Sat Dec 05, 2015 11:18 am
Must be a common problem. I just checked mine and milky oil oozed up out of the fill plug. Where's the water get in?
Also, what's the oil type and capacity? (5-speed w/Reverser)
JD420C, Ford 3910, IH 2606, Kenbota G32XKS
Post by Stan Disbrow » Sat Dec 05, 2015 1:11 pm
If rain can get to it, and the boot is in bad shape, the shifter.
But, this need not happen. Over time, heating and cooling of the days and nights brings in water vapor with the air thru the vent. The vapor gets in, condenses, and stays. Eventually, some milkiness will be seen.
Users browsing this forum: No registered users and 78 guests
