40c safety blocks
40c safety blocks
Someone has removed the safety blocks from my 40c. I don't know how important they are but I would like to install a pair. Does anyone have a pair or know where they might be available. Used would be good. Part #s are:
M2386T safety block (2)
M2387T V bolts (4)
TE273YT shims (qty ?)
All are for a 4 roller 40c serial#62264 and up.
M2387T V bolts (4)
If a rock gets inside the chain, it will pull the entire frame such that the safety block binds the sprocket and stops the machine before it rips everything apart.
I have them on hand.
- mapaduke@yahoo.com
Hydraulic vs. Spring tensioners.
The hydraulic loosen the tracks. The springs don't. So, with springs you need to halt the drive before it snaps the axle or final drive housing from all the pressure.
Just one of many little improvements they rolled into the 440.
I'm not doubting you Stan, still a little confused.
There is a spring behind the hydraulic adjuster on the 440?
The only difference I see would be in the actual adjustment unless the 440 spring allows more compression than the 40/420 springs thus not needing the safty block?
nothing crawles like a deere
There is a spring to allow for some leeway, then a pressure vent on hydraulic tensioners to allow the grease to spit out and unload the tension on the track. So, when the rock gets in there, the track will pull back and stay that way.
With the older double springs, they compress to a point and then the loading goes up when they run out of coil space. So, there are blocks to jam the sprocket and stop everything. That scheme tended to not work all that well, actually. Better to unload the tension and have a floppy track in the end than busted stuff.
These machines were really a whole series of running design changes from the MC thru the 1010c. They were constantly improved every couple of years along the way.
It is easy to see this in engines and reversers. Not quite so easy to see in undercarriage, but it is there as well. And not just in extra rollers.
By the time they got to the 'JD' Series, they had it pretty well nailed down. Which is why we split the forums up at that point.
440 final drive is bolted solid to the rear crossbar, it is not possible for it or the sideframes to move, so track stop would be useless.
