MC steering clutch adjusting tool
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Sun Dec 27, 2015 7:18 am
Getting ready to put the final drives back on and want to fabericate a wrench for adjusting the throw out. I don't have the tall adjusting screw just a bolt and washer in the carrier.
What do you guys use? I thought of using a crowsfoot but it doesn't look like it will have the reach.
nothing crawles like a deere
Post by Lavoy » Mon Dec 28, 2015 9:16 am
Without the tall adjusting bolt, not sure you will be able to get on it. I use cheap 1/2" wrenches, cut the ends off and weld them to small diameter rod and make my own.
Post by Stan Disbrow » Mon Dec 28, 2015 10:50 am
A couple points about making these tools. Use six-point not 12-point, then grind off the chamfer on the business end to make 100% hex contact.
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Mon Dec 28, 2015 4:36 pm
Thanks guys, I will get a sacrifical wrench 12 point and cut the open end off, bend it and weld a rod to it for a handle. I will grind the chamfer off to.
Post by jtrichard » Mon Dec 28, 2015 5:21 pm
Stan Disbrow wrote:Hi,
SIX point is the best as said by STAN the man :D :D
Post by Stan Disbrow » Mon Dec 28, 2015 6:43 pm
Yes, 12-point tends to not grip all that well, and when on nuts and bolts you would really not want to booger up, you really want a 6-point.
Now, that does come with a bit more trouble lining one up. So, sometimes that can be an issue. But, for sockets anyway, the 4-point drive is offset to the 6-point business end such that if one pulls the socket off and rotate it one flat on the drive it then offers a different alignment.
So....that equates to a 6-point offering the same number of get-it-aligned points as a 12-point. :)
Users browsing this forum: No registered users and 57 guests
