420 engines
kevencyr
420 engines
Post by kevencyr » Tue Mar 22, 2016 3:42 pm
hey guys, me again :D , is there a reason why i got 2 420 crawler engine, one is green and the other yellow, oil dip stick is different and piston in the yellow is a little bigger, also by comparing both piston, one look like its was made stronger, thickness of the piston is bigger on the yellow one. also got one removed, any idea how i could get the other one seized, so far no luck. thanks
Col_CCC
Post by Col_CCC » Tue Mar 22, 2016 4:37 pm
Unseezed? We lifted the front of ours w a chain fall. Then blocked the bottom and lowered it back down. Also fill the cylinder beforehand w auto trans fluid and let it sit for a few days
Chris
Post by Lavoy » Tue Mar 22, 2016 8:55 pm
If the difference in bore diameter is 1/4", then one is a 420, the other is a 40. All 420, 430, 440 blocks use all the same internals.
blakearmstrong2016
engines
Post by blakearmstrong2016 » Thu Mar 24, 2016 2:54 pm
yes soak soak soak with oil I also use pb blaster or marbrol mystery oil has worked many times well for me on marine engines
j blake Armstrong
1956 JD 420C
1952 8n
1954 Divco stand up milk truck
196? ford4500
1969 ford4400
2001 ram 2500
procharger02@yahoo.com
Post by Lavoy » Thu Mar 24, 2016 6:21 pm
Large wood block, slide it down the bore and hit with hammer to loosen up. Steam cleaner with zero degree nozzle down alongside the piston to loosen the rust. Clean all the petroleum product of any sort out of the bore, and fill with water. Lots more, but that will get you started.
gregjo1948
Post by gregjo1948 » Sat Mar 26, 2016 4:07 am
I've had good luck using Coca-Cola.
Users browsing this forum: No registered users and 71 guests
